moresmoke
Jan 30, 2019Explorer
ktmrfs wrote:
as for -35 and it won't come out of the pump, well, likely not true unless it is an above ground tank with untreated fuel. If the tank is below ground it will likely be around 50F year round, and worst case likely never below freezing.
I have spent my fair share of time on the side of the road thawing gelled fuel. I hope I am past that point in life.
If the diesel pump has a filter on it as it should, you may get a gallon or so of untreated fuel out of it in extreme cold temperatures, then the filter will plug solid and you will be done.
I went and got a Semi down south last winter. Stopped in Iowa to get fuel, there were 15 pumps with #2 fuel, and 1 with winter blend. Lady at the counter couldn’t believe that I actually wanted to buy winter blend fuel... “Lady, I am headed to Fargo”.
Understanding Cloud Point and CFPP (cold filter plugging point)
Cloud point
All fuels must be blended 5-10 degrees above cloud (fuel temp not air temp)
Significant variation between fuels
Typical #2 cloud pt – 6 – 14 degrees F
Use pipeline spec as baseline
CFPP
Usually within a degree or two of cloud point in an unadditized fuel
Winter Fuel Blend Chart
#2 Diesel Fuel, Ruby Fieldmaster™ & Cenex Roadmaster XL™
Product CFPP* w/o Cold Flow Additive CFPP* With Cold Flow Additive
100% X or D grade +10°F -3°F
90% X or D + 10% #1 +7°F -6°F
80% X or D + 20% #1 +4°F -9°F
70% X or D + 30% #1 +1°F -12°F
60% X or D + 40% #1 -2°F -15°F
50% X or D + 50% #1 -5°F -18°F
40% X or D + 60% #1 -8°F -21°F
30% X or D + 70% #1 -11°F -24°F
20% X or D + 80% #1 -14°F -27°F
Note: This chart is for guideline purposes only. Diesel fuel low temperature characteristics may vary substantially from one source to another and this chart assumes the product meets typical specifications.
*CFPP (Cold Filter Plugging Point) is the temperature at which wax crystals will plug a fuel filter.
WINTER BLENDING WITH BIODIESEL
• Blending of neat biodiesel (B100) with petroleum diesel should occur when both product are 40 degrees F or above.
• Low blends (B2 or B5) typically have very similar (within 0 to 5 degrees) Cloud Point and CFPP characteristics to conventional diesel products and can be treated in a similar fashion #1 blends, Winter Aid III additives, or both.
• Animal fat or higher level soy blends may increase the CFPP of the fuel as much as 5 degrees for every 10% of B100 used.
Impact of #1 Fuel
#1 fuel typically has a very low cloud point
(-40 to -70F)
#1 blended with #2
reduces the cloud point and CFPP of the blend
“Rule of Thumb”
Adding 10%-#1 will decrease the cloud point by approximately 2 degrees
#1 when blended with 5% or greater with biodiesel will have a negative effect on the cloud point
44,071 PostsLatest Activity: Aug 30, 2026
