Community Alumni
Nov 10, 2017Not applicable
There isn't much money to be saved by buying washer fluid, like only a $1. Walmart's selling cheap washer fluid for $1.58 while Propylene Glycol antifreeze (the good stuff) is going for $2.58. The advantage to antifreeze is not only can you put it in the tanks and traps, but you can also put it in the lines. It can also be used to replace the water in the toilet to maintain the seal while in storage.
