- Bionic_ManExplorerI have owned a diesel since 1998. Never used any fuel additives.
- boogie_4wheelExplorerI've been using Howe's. Kept my truck running in -22*F.
- xaugievikeExplorerI run optilube - the regular xpd or whatever they call it year round. last year during a very cold snap (-10 it was) i believe i experienced gelled fuel. So now when it gets uber-cold like it's supposed to for the next few days i get a quart of their "winter" formula and add that to a full tank of diesel.
- mowermechExplorerWhen I had my Dodge diesel, the only time I used an additive was when I didn't get winter fuel in the tank in time. I had to wait for a relatively warm day, add the anti-gel stuff, and it started no trouble. Of course, I promptly filled it with winter fuel, and there was no further problem.
That was the ONLY time I ever used any fuel additive in that Dodge 3500
But, such stuff doesn't cost all that much. Pick one that claims to have anti-gel properties, follow the instructions on the bottle, and get on down the road!
For a good comparison of the various brands, look up the MSDS for each one. You will probably find that they have pretty much the same stuff; a solvent (90%+), light petroleum oil (5% more or less)
Here is the MSDS for Power Service Diesel Kleen to get you started:
http://www.powerservice.com/msds/pdf/dk_msds.pdf
Here's the one for Optilube XPD:
http://opti-lube.com/downloads/MSDS/Opti-lubeDFI_XPD_MSDS.pdf - alexleblancExplorer
brirene wrote:
Power Service Diesel Kleen; white in winter, silver in summer.
I used thus stuff in my previous and current diesels and have never had a fuel related issue, must work. - ChooChooMan74ExplorerLast year, I used Stanadyne with no issues. This year, my small diesel parts store started carrying optilube. No issues in -10 this morning.
- SDcampowneroperExplorerPower Service diesel treat. Allways works in the coldest weather for after treatment. For lubricity always and anti gel pre treatment, Howes.
Be liberal with the dosage at first. - 45RicochetExplorerPick one
I use the Opti-lube just in case. But if your area has a good bit of winter the fuel should be blended correctly for your area. If it's a fluke cold spell say in South Texas, I'd be adding something at 8 below.
You can always keep it running to keep the fuel from waxing up also, although that might get expensive :E - VoodooMedicineMExplorer
X2 - brireneExplorerPower Service Diesel Kleen; white in winter, silver in summer.
44,052 PostsLatest Activity: Nov 23, 2025
