IDoMyOwnStunts wrote:
1. The specs say you have a forced air furnace with ducted in-floor heating. Are your propane bottles open? Have you checked your thermostat? From the limited pictures I can find of your unit, it looks like the thermostat might be by your TV. It looks similar to mine. Switch it via the bottom button until the green light is on heat, then adjust the temperature up Good luck!
Yep, I've been using that. My question is when I put the furnace on is it using electricity or propane??? That's what I'm not understanding and confused about. Thanks!
