egarant
Jun 29, 2015Nomad
ISBRAM wrote:
I’m wondering if the new low noise fan cuts back on cooling efficiency; has anyone else thought the same thing?
An air-conditioner does not make cold, it transfers heat to the outside. If the fan is noticeably quieter is it also less efficient at removing heat from the A/C evaporator coil?
egarant have you tested it both ways?
Yes, I had the opportunity to use the unit with both the different fans. Same result.
When the outside temps are between 90 and 110, and that is regular occurance where we camp in the summer, the 9,200 will not handle it.
I look forward in testing the 15,000K unit, as soon as I get it installed it's first test will probably be Lake Havasu, AZ.....
