jus2shy
Jun 29, 2016Explorer
Cab lifting can happen on the HD Rams as well. There's 1 oil fitting that's pretty impossible to get to otherwise at the back of the cylinder head. But it's an extremely rare failure point on the motor.
But I've seen cab-off on all 3 vehicles. It's just that it was far worse on the 6.4 equipped Ford which made it more SOP. All 3 can have just about everything done cab-on now a days. Even the Ford 6.7 can have its heads replaced cab-on, but since Ford built the cab around easy removal for the 6.4, if something serious is required, they will just remove the cab to get at the engine/trans setup more easily.
