rickhise
Nov 29, 2017Explorer
Compact gas grill
What’s on the market that is popular for Rv er’s, in the way of gas grill collapse able an compact stow away. Usually 2 adults an 2 young ones Thanks
SoundGuy wrote:ZeeLet50 wrote:
I have an quick connect at the back of my camper. Will the Weber work with this if i get the right connections or do i have to get a different regulator?
It'll work just fine but requires removal of the Q's regulator so you can feed your trailer's low pressure quick disconnect feed directly to the Q's low pressure burner. The gas valve is separate from the regulator so you still have control over the size of the flame. All you need is a hose with the proper size quick disconnect nipple to match your trailer's quick disconnect fitting and the correct size of threaded fitting at the other end of the hose that will screw on to the Q in place of the regulator.
