sabconsulting
Jul 21, 2015Explorer
Compressor fridge - considering adding internal fan
Guys,
Resurrecting an old discussion here - that of adding an interior fan to a fridge. The difference here being a compressor fridge.
I have a Waeco CR140 - 140 litre compressor fridge. It has an exterior fan that comes on when the compressor runs, and I have ducted the air flow so it is forced to suck in exterior air through the heat exchanger and vent it out of the top vent - i.e. to prevent it just circulating hot air inside the space where it is fitted.
But I notice the compressor is still running a lot more than I would want.
Checking the other day I noticed that the back wall of the fridge was frozen even though the cheapo analogue fridge thermometer I have hanging in the fridge showed the temperature was at the top range of what you should have, at least on a domestic fridge.
I suspect I have the fridge set to quite a high setting causing it to run a lot simply to achieve an acceptable temperature in the middle / top of the fridge, but all it is doing is freezing the back of the fridge because the cold is not getting distributed well.
So I am thinking of fitting a small equipment fan internally, run off the fridge thermostat, to blow the air around (probably blowing the air in the fridge against the back wall so as to distribute the cold a bit more evenly.
Hopefully then the compressor would run for less time - the thermostat would click on and as well as the compressor the fan would run and redistribute the cold for a while. The thermostat would then sense the temperature had been reached more quickly and switch off the compressor rather than wasting my battery power.
Does this sound sensible?
Also, any advice on fans?
Thanks in advance,
Steve.
Thanks in advance,
Steve.
