- dbertheauExplorer
DieselBurps wrote:
Engal doesn't make a unit that will fit my opening. I would rather have a top loading arb or engal but I already have the non working 3 way fridge in the camper.
Dan how many amps does your Dometic CR fridge draw?
Average power consumption of a CR110 is 45 watts. - DieselBurpsExplorerEngal doesn't make a unit that will fit my opening. I would rather have a top loading arb or engal but I already have the non working 3 way fridge in the camper.
Dan how many amps does your Dometic CR fridge draw? - DieselBurpsExplorerI didn't know Engal offered built in models. I will have to check that out. Right now it appears the Novacool 4500 is the one that will fit my cut out. I have two 6 volt batteries and plan on installing as much as 240 watts of solar.
- hedgehopperExplorerOur previous TC did not have a freezer. So we used an Engel MD14F portable fridge-freezer as a freezer for several years and were quite happy with it. It drew very little current and kept food near 0 degrees F, even in hot weather. Engel offers built-in models too.
- sabconsultingExplorerYes, Waeco and Dometic are now the same company. Waeco made the compressor fridges.
I agree with the suggestion to also look at Engel fridges. These chest-style fridges seem much more efficient - I've used them in South Africa and Namibia.
Steve. - DWeikertExplorer II
spadoctor wrote:
I don't see any compressor units on Dometics site
Dometic lists the compressor refrigerators under their marine products.
To the OP, I have the Dometic CR-110 in my Northstar and I'm happy with it. Afraid can't offer any comparisons to the Novakool, all I can say is I have no complaints with the Dometic.
PS: Be aware you're going to want to have solar if you plan to camp without hookups, if you don't already. - dbertheauExplorer
I installed a Dometic CR110 in my Lance. No issues. I've seen these fridges under the name of Waeco as well....could be same company just different brand; I think these are targeted as a marine fridge while the evaporator versions are targeted to RVs. - JimK-NYExplorer IIYears ago it seems that there were issues with some of the Dometic units. I went with NovaKool and have been happy with the unit. I also liked the idea that Dometics is a conglomerate and NovaKool only makes refrigerators. Novakool is Canadian and uses German Donfoss compressors.
- spadoctorExplorer III don't see any compressor units on Dometics site
44,054 PostsLatest Activity: Dec 15, 2025
