720Deere
Oct 17, 2013Explorer
When people breathe in small spaces, they add to the humidity level. Propane heat always causes humidity problems. Keeping a vent slightly open helps. Ultimately being able to use electric heat and avoiding the propane furnace would be the best bet. Unfortunately, most campgrounds frown on electric heater usage even though they are probably charging you close to the same rate that they would in the Summer if you were running 2 - 15k AC units!
44,066 PostsLatest Activity: Jul 25, 2018
