pianotuna
Jan 30, 2021Nomad III
time2roll wrote:
I assume the humidity is much lower outside so it might seem counter intuitive but you may benefit from cracking a window or two open.
Since we measure relative humidity, it is actually higher outside. When the air is brought inside and raised in temperature it becomes dramatically drier. That is why opening a roof vent a bit and the window farthest from the vent works to lower the RH. It works even better if there is some shore power to run an electric heater near the window.
