Gdetrailer
Jan 31, 2021Explorer III
Skinny D wrote:
Thanks for all the experienced folk who weighed in here.
The indoor humidity is about 48% to 62%, but I don't have a meter that gives the 24 hr high/ low.
I should clarify the reason that I care. It's not the cosmetics of beads on the window and it's not concern for damage to the TT. We are in the snowy mountains for skiing, and we have lots of wet gear at the end of the day that needs to dry out before the next morning. I'm concerned that the accumulated moisture on the window will just be eventually returned to the air and my clothes/boots won't dry as well (starting a ski day in wet gear is not ideal). So, I'd like that window moisture to be discarded somehow or redirected to the dehumidifier.
The window covering option seems best (creating double pane windows) but this seems permanent? Do you remove and re-apply it each year for the different seasons? Is there no "super sponge" option for wiping windows and collecting that condensate?
As I mentioned, there is built in "drains" in the windows, they are hidden from view, moisture collects on the window surface then rolls down to the bottom.. At the bottom of the window there is a couple of well hidden drains that send the moisture to the outside of the frame.
Take a close look at the outside of the window frame, you should see two plastic "covers" at the bottom of the frames.. Those are the drain points.
You should not have to "mop" the moisture at the bottom of the window frame unless the drains are clogged..
Drains are there to help redirect any moisture that gets past the window slide gaskets in heavy rains..
Won't hurt to mop it but not really needed..
Damp clothing/gear however can be an issue and makes the inside humidity more of a problem to deal with.
Keep in mind, if it wasn't for the windows collecting moisture, EVERYTHING ELSE would condense and collect the moisture.. It is not unheard of to have moisture dripping from ceiling or running down the walls and that is what you want to avoid.
Dehumidifiers can only help so much and they tend to not work effectively once the ambient air temps drop below 70F due to freeze ups of the condensing coils.. Granted most expensive dehumidifiers have a freeze sensor but when that trips it is too late and you end up with a solid block of ice on the coils blocking the fan. That ice has to melt so the compressor turns off and the fan runs until the ice melts and falls off the coils.. Wasting a lot of time and electricity..
To myself, it seems if the clothing and gear is the big issue then you need a way to dry those items before putting into the RV for the night.. RVs typically are not designed to cope with huge amounts of moisture. RV washer/driers tend to be pretty small and inefficient for drying..
