rhagfo
Dec 18, 2014Explorer III
RedRocket204 wrote:Cummins12V98 wrote:
Good choice on the last of the 5.9's. IMHO always get more truck than U need so you can and will get a larger RV!
Rock solid towing is awesome!
Absolutely!
That second truck will be a much better choice even with the 143k miles...it should last well beyond that mileage.
Do yourself a favor though, make sure and pay an independent mechanic to do the once over on it to make sure a previous owner didn't monkey with it or let maintenance go. Having that data is also useful as a bargaining tool in the event it is uncovered that something minor needs repair.
Per your questions about the truck stopping the trailer...each trailer should have adequate brakes that will stop the added weight of the trailer. If you are buying used, also a good idea to have the trailer brakes inspected along with the wheel bearings greased. Equally important is making sure the brake controller is set correctly. Given all that, either truck will safely stop the trailer.
Now, exhaust braking is different.
He is looking at a Cummins, that engine is just past break in! :B
I didn't think twice about buying a Ram with 234,000 miles, (One Owner). We are currently at 277,000 and going strong. We pull and carry a 5er the same size as you are looking at, you will not have any issues with power or longevity.
