rhagfo
Dec 19, 2014Explorer III
BrianMullins wrote:
OK folks I just left the dealer and this is the information I found. 2005 Silverado 2500 4WD Crew Cab LS Disel. Duramax 6.6L, Allison Trans, Gear 3.73. GVWR 9200, GAWR front 4670, GAWR rear 6084, GCWR 22,000 if I looked at the correct number. Pulling a Keystone Sprinter 5th. Wheel. empty weight 9526, carrying capacity 3224, hitch weight 1875. The only thing I didn't find was if the truck is HD. Any Help?
You also didn't get the payload for the truck. That 5er will likely put you over the GVWR of your truck, should be within the axles ratings, as your rear axle is the same as mine and I carry a 2,000# pin and have about 634# of spare capacity on the rear axle (carry 5,450 on rear axle), that said last scale the truck scaled at 10,000#. :E
