westend
Jan 27, 2016Explorer
Silicone on an RV is the devil! It degrades relatively quickly when exposed to UV and weather. It's especially devilish characteristic is that it will loose the adhesive bond and still stay intact, looking like it is still sealing.
The good news is that it is easy to remove with modern caulk removers. I've had good luck with 3M Caulk Remover. Apply the caulk remover, cover with Saran wrap and come back 12 hrs later. You can then remove it with a rag. Wipe down the area with solvent, mineral spirits or acetone. Then, apply a polymer based sealant. Geocel 2300 is the type I now use. It is a sibling of Proflex RV.
You don't have to believe the silicone cautions. Prove it to yourself. Apply some beads to some metal and lay the metal out in your back yard. Watch it for deterioration.
44,066 PostsLatest Activity: Jul 25, 2018
