hedge
Apr 19, 2017Explorer
Can't help you directly but I found it easier to tap wire from the 7-pin umbilical bundle. I installed a Garmin BC30 and drilled a hole above my door and ran the the wire from the camera inside. Then I tapped into the Reverse wire and ran the wireless transmitter up to the front wall of the camper (needed an extension cable).
I later added another wire from the truck's upfitter switch so that I could trun the camera on at will via the switch. I didn't want it powered all the time as then I'd have to select it from the menu all the time.. and my monitor is also my gps and my dashcam.
44,071 PostsLatest Activity: Aug 30, 2026
