Dr_Quick
Nov 13, 2013Explorer II
RV antifreeze needs to feed into pump from the same line that is connected between your fresh water tank and pump. It sounds like you are connected to pump outlet line. Just switch to other side of pump and see if that helps. If line is difficult to get to, you may be able to get a piece of line and connect to pump inlet. Then stick other end in jug of antifreeze.
Also make sure that you use RV antifreeze , vehicle kind is POISON.
44,027 PostsLatest Activity: Mar 05, 2025
