- westendExplorerGotcha' now. I don't know if Furrion makes an adaptor. You could DIY and get the conventional RV 30 amp female and the Furrion power inlet, making your own pigtail.
- GoldstalkerExplorerYes, two main cables. Just hoping there was a pigtail or something simple to connect them when needed.
- curveballer98Explorerare you talking rv extension cords, or two of the main cables that you would hook your rig to the power pole with? just buy a a couple male and a couple female ends and wire them up to the cable..if it's just the wire that you have. that way you will have to extension cords or the ablity to connect them up.
- GoldstalkerExplorerI have two of these and would like to link them together.
http://www.campingworld.com/shopping/item/30-amp-rv-cordset-with-fault-smart-led-25/69580 - westendExplorerDo you have a power inlet on the trailer? If not, the loose cord may have the correct ends for making your longer run, no adaptor required. More info is needed, I guess.
44,070 PostsLatest Activity: Jul 21, 2026
