SideHillSoup
Jan 08, 2018Explorer
I just bought my new truck 3 months before I decided to sell the 5th wheel and go with a camper. So right now I have a 1ton short box GMC diesel crew cab, with a Northern Light Camper with no slides and shower toilet.
If I had to do it again I would be this.
- Truck
Same truck but in a long box, I’m a GMC type guy, but there are a lot of larger weight class fords out there I think they go as large as an F-450, I could be wrong on that.
I have a diesel becuase I was pulling a 35th 5th wheel in the mountains I you need the power up here. You also get better mileage in the mountains with a diesel. The diesel will cost more than a gas powered truck to service and repair, but the longevity of the diesel is something else I liked.
- Year of truck
if a diesel, it will make a difference on pollution control devices on the truck. Up here in Canada the DEF ( Diesel Exhaust Fluid) was started to be added to new trucks in 2007 by 2010 it was on all diesel trucks. It’s is relatively cheap ( $11 USA $ per 2 USA Gals) but is a pain to add and it is just one more thing you have to buy for your truck for its life.
- Camper
Same camper but a longer one to fit the 8ft Box
- slides
as I don't like slides period. The years when I had my 5th wheels I had to many issues, and becuase we were going to be doing a lot of off pavement traveling slides were definitely out of the picture. So when I researched for what camper to buy, I stayed completely away from slides.
Becuase you have kids you may want to have a slide just for elbow room inside, however when you add a slide to a camper you add on average 800 to 1000 lbs.
also when your camping, are you inside or outside? My wife and I only are inside only to cook if the weather is bad, sleep and use the bathroom, we are outside 100% of the times besides those three things. So for us, another reason not to get a slide was why would need the extra space and then hardly use it, but pay in fuel economy to have it?
- camper materials
Becuase this camper will be staying with us for ever, I also did research on what makes or what type materials last longer. I also know from buddies with different types of campers, like manufacturers, wall and roof materials etc what to looks for and stay away from. Wasn’t long before I went and stayed with a Fiberglass Camper Northern Lite.
-Getting in the camper
once my wife saw the stairs on the back of the Northern Lite campers she was sold on them, no if and or buts about it. Not kidding, she saw those stairs and was in love. Look at how your going to get in the camper. A lot of older campers don't have the stairs attached to the camper like the newer ones are starting to come with, so that is really important.
- dry rott
My buddy was just over at Christmas who owns a older camper, which he bought new in 2004. Last fall while out hunting he tripped going up the stairs and came down hard on one step and the whole thing broke off the back of the camper, lucky for him he had is hand on the grab handle. He keeps his camper inside his huge shop at home so it is kept inside when not in use. When he took the camper apart to repair he found that the seal around the door had failed at sometime and would allow water in side u dear the metal siding, over the years it rotted away.
Also you will see on a lot of older camper like my first camper a long time ago is where the camper jacks mount brackets are bolted onto the camper corners, will have different size beds on bolts as well as large amounts of different caulking like silicon globed on. If you see this “stay away”, or run away would be better. That usually means the bracket came loose at one time and someone added a bigger bolt to the hole and then gobbled on some kind of caulking. Usually the bracket came loose because water got in behind the bolt head and then followed the bolt into the wood and rotted it.
When you checking the camper before you buy it, push gently on the ceiling, if you hear small cracking or you see small bubbles in the ceiling material, run, it usually means the roof has leaked at one time. Also get a ladder and look on the roof from the outside. If you see a big glob of caulking / silicone what ever, run, that will usually mean they roof leaked In the same spot more that one time, you get the picture.
- Duelly
If you buy a duelly make sure the front jacks on your camper have the swing bracket, so that the jacket will be wider than the fender walls on the box of the duelly truck. I never even thought of that until I ordered my Northern Light Camper and those brackets were an option on the list of things we could get.
Your buying second hand so price will have a lot to do with what you are buying for both rigs. The list above is only what I though about before and since I bought my truck and camper. Everyone will have different options, that’s the beauty about this site lost of different info coming your way.
Good luck.
Soup.
- Truck
- Year of truck
- Camper
- slides
- camper materials
- dry rott
- Duelly
Good luck.
Soup.
