jimh406
Jan 22, 2018Explorer III
Older DRWs or SRWs for that matter, don't have the same capacity as newer ones. Although you could start with a SRW, you'll be way ahead with a DRW Crew Cab. If you plan to tow or carry extras on the hitch on either front or back, your capacity requirements go even higher. Hence, the recommendations for a DRW.
You don't need a diesel just to haul a TC. Sure, they are nice in the mtns, but you also could just slow down.
If you look into prices, you may find that other RVs better suit you especially if you don't need a truck for any other purpose.
Good luck.
Good luck.
