SoonerWing03's avatar
SoonerWing03
Considering a Used TT: What to look for
This evening we are going to look at a used TT. It's a 2016 Cruiser Rv MPG 2400BH so it's not very old but I was hoping to get some specific things to look for and some specific questions to ask the current owner. I guess my concerns with buying used is the risk I take in buying someone else's problem. According to the pictures that he has sent me it appears to have been well maintained but I am anxious to actually see it in person.
  • If you're serious, see if you can find a mobile RV mechanic who you can pay to do a full inspection.
    In my case there were 2 things missed. First was an area on the roof damaged from a tree and that meant there is some leak related damage in the wardrobe below. Second was the unit had not been winterized and the diverter for the shower failed shortly after we started using the unit.
    Overall I'm happy with the roughly $10K we saved over buying new.
  • As stated, If the owner has to dig or him-haw around for answers to basic questions about the trailer - beware.
    1) Stand at the back or front of the trailer and look down the length.
    - Do you see wavy walls, or bumps in the wall? This could be a sign of delamination.
    2) Look under the trailer.
    - Look at the frame for bad rust or broken welds.
    - Look at any exposed wiring or plumbing for possible breaks or frayed wiring.
    - If the bottom is not enclosed, look at the Floor of the trailer for any water damage.
    - If it is enclosed, look for any "access ports" that may have been cut into the Coroplast to gain access to the items between the floor and the plastic.
    - Look at the backing plates on the wheel assemblies. Check the wires for bad or cracked wires.
    - Check for grease or oil on the bottom side of the backing plate, it could mean that grease has gotten past the wheel bearing seal and contaminated the brake assembly inside.
    4) Look at all surfaces where the walls connect.
    - Corner joints - missing screws, bad/missing caulking
    - Where walls have holes cut in them (Windows, water/electric access, etc). Make sure that they are sealed on the TOP side (Some windows have been found to not be sealed on the top but were on the bottom - creates a nice water access point)
    5)Roof - Check All the caulking points (roof edge, Anyplace where something goes through the roof, Etc). Water can come in one place and damage someplace else.
    6) Floors.
    - Walk around the entire floor of the trailer. "Feel" for any give or soft spongy spots. This could possibly mean that the floor is coming apart. If you are not heavy enough, take someone with some heft and have them walk on the floor. Check near the Kitchen, where the floor meets the wall, over the Wheels (possible water intrusion from tire spray), bathroom...basically the entire floor.
    This list is no where near complete, but it will give you a start. If you find any of these problems in a 2-3 year old trailer I would avoid it. Unless you are Bob Villa and you can get the trailer for chicken feed...Heck, I would still avoid it.
    YMMV, Check your dealer for details...Just my 2 cents.
  • Leaks, leaks and more leaks.......
    Look at all the places where the roof meets in the inner walls and look for
    and stains on the inner wallpaper. Look for any leaks around the windows/doors.
    Get on the roof and inspect the caulking.
    Follow your "gut" instinct - does it smell funny? did the previous owners clean it up before or does it look like a mess inside?
    Does the exterior look clean?
    Check all exterior for any lumps - especially on the front
    Are there any brown streak at the bottom of the fiberglass exterior?
    Check all appliances
  • Water damage is the killer. Look for staining, delamination (wavy outside walls), soft floors.
    Also be aware that a 2016 might have actually hit the road in February or March of 2015, so it is older than you think.
  • My very biggest concern would be leaks. If it has had them walk away.
  • The first question you should ask the seller is, "Why are you selling the camper?" If they hesitate or have to dig up an answer, chances are there's problems with the camper. If they immediately say, We hate the floor plan. We can't afford the payments. We don't like camping at all. It's too expensive. My husband got laid off work and we can't afford the payments any more.
    Any of those types of answers would not raise red flags as far as the worthiness of the camper and would put me at ease right away.
    However, if there is hesitation, or they have to think up an answer, chances are there's a real problem with the camper they are hiding. Proceed very cautiously an with a real skeptical eye.
    Ask the current owner where they purchased the camper from. Ask to look at the camper documentation (all that paper work that comes with the appliances and the owners manual... as flimsy as that is). Take a few minutes and look through it all. Then go check with at dealership they purchased the camper from and ask the service department if would provide any history on warranty repairs done. You might be shocked what they would tell you.
    If there is any hesitation on the seller's part to provide this information to you, they are hiding something detrimental to the camper.
    You might even ask if they have a current loan. If they do, how will you get the title once you give them the cash?
    If all this is satisfactory, then start looking for water leaks and check for breaks in the trailer frame. Yes... remember to crawl under the camper and inspect it there too. You might not like what you see.
    Anything you can see will probably be OK. The appliances, the lights, stuff like that. The obvious is not what they are hiding. Don't focus on the color of the walls or the color of the sheets on the bed, when there may be a weld broken on the frame!
