Currently: 2013 GMC Terrain V6 Automatic(Select Shift) Towing 2900 lbs
Type II Frame mounted Tow setup. (1 1/4")
Tongue weight 300 lbs
Rated at 3500 lbs/350 Tongue
2010 Palomino 4120 w/12 foot box.
I have installed Electric Brakes and a P2 Controller.
I use a friction type sway control.
I'll probably sell it if I buy:
I'm thinking about a 2016 Coachman Clipper 17QB from a local dealer (AZ)
Lists at 17,000 Offered at 14,900
I'm going to have to change to a Type III hitch setup (2")
The listed hitch weight is 298 lbs, + Battery and Propane
(It's questionable if I need a WDH)
It has all the stuff that you (and DW) are looking for.
UVW=2731 - GVWR=3518 - CCC=770
33 Gal FW, 25 Gal each Grey and Black
Overhead storage, small fridge w small Freezer
Might be worth looking at.
