northshore
Oct 19, 2020Explorer
First off, go for it.build what you want how you want it.
If I was doing this, (I built our home) I would point out a few pit falls that got me in the past.
First thing I truly believe you could not build a camper less expensively than buying a used one, a camper that is in good shape with no water damage. There are some out there.
If budget/expense is your main focus, I don't think you could do it for less money than buying a good used unit. If a custom built, what you want, how you want it built, where the budget is no object, camper then you are on the right track.
I think $5000 is probably wishful thinking, materials add up like crazy these days, $5k would not go far when buying quality materials. Im sure you could build it for less than $5k but I don't think it could compare with factory built unit in looks, utility, comfort. and quality.
I think it all boils down to what you want, how much you want to spend and being happy with the final outcome of the unit you decide to build.
I am retired now but when working for a large organization, capable of building anything we needed. We always ran the numbers on "build/buy" and what made the most economical sense of the item we needed. Its surprising how many items were cheaper to just buy vs building in house.
