BigfootBill
Oct 21, 2020Explorer
If you are doing a full build with metal and are planning on hard mounting, why use a flatbed? If you can use the deck that sits on the frame rails and structural supports for the "truck camper" you would be able to shave cost and weight. Consider doing a frame mount build - think hook lift truck but you dont necessarily need to use that style of system to install and remove it.
You can install a separate flatbed or dump body, etc when you want to use the truck for other purposes.
