WandaLust2
May 30, 2013Explorer
Buying a leaky RV can be a nightmare. We just went through it with our 1993 Class-C. Had we known it leaked we wouldn't have touched it with a 10' pole. But the seller lied about almost everything. The leak can be from either the window or the roof. If he reset the window in new putty-tape the window shouldn't still leak. It's bigger job but it works. If all he did was run putty or silicone around the edge, it can still leak as before. Same goes for the roof repairs. What did he use to repair the roof and stop any leaks? The water can be coming in from far from the wet spot - that's just where it found to leak down behind the wall. Leaks are the bane of all RVers lives.
44,056 PostsLatest Activity: Jan 12, 2020
