4x4ord
Nov 28, 2017Explorer III
I see the grawr is a little higher on the new truck (7230 lbs) but the truck must have gained a few pounds....I think the cargo carrying capacity is about 150 lbs less. They rate it for pulling a 21000 lb 5ver and give it a 3300 lb cargo carrying capacity???? A couple occupants and a good hitch might weigh in around 500 lbs so I guess a 2800 lb pin is all its really rated for...so 14000 lbs is a little more honest. Personally I will have no problem loading it to its gross rear axle weight rating. I'll find out tonight what the curb weight of the rear axle is.
44,071 PostsLatest Activity: Aug 23, 2026
