This is a typical 30AMP Power Distribution of the RV Units... They are all there for a reason... The RV Trailer is a very unique functional design and loved by many users. I would not disable the 12VDC source as you can see a whole lot of your trailer systems uses that. It is not just for boondocking...
There are some SAFETY ISSUES as well that only runs on 12VDC... One very important safety issue would be the CO DETECTOR...
Take a look at all the items that are connected to 12VDC side of the power distribution. None of those will work if you remove your 12VDC source of power (Battery and Converter/charger). The parasitic drains associated with all the 12VDC controller and other connections for your appliances will drain your on-board battery in less than a week. It will just barley last over night night if you are running your 12VDC BLOWER associated with the 120VAC Furnace operations.
Another issue is your BATTERY will not be maintained when connected to shore power. The BATTERY is a very important item and is required by DOT to be operational when you are towing your trailer over public DOT roads. You would be breaking a DOT LAW by not having the 12VDC system but more importantly be a safety hazard in the eyes of the law. This could go very bad for you if the runaway trailer did alot of damage or worse and your insurance would most likely not cover you... This 12VDC is required to immediately activate your trailer brakes in the event your run-away trailer becomes disconnected from your truck when going down the road. This is a DOT SAFETY requirement...
Good luck with your decision on not using the 12VDC side of the power distribution center. As you can see the 12VDC is really required to operate most of your trailer installed features.
Even your AM/FM radio will not work without 12VDC power... No Johnny Cash country music for you my friend haha...
Just my thoughts
Roy Ken
