Most electronic device "hum" is typically from a dirty/unlubed fan or from a transformer and it's separate plates.
Solutions: Clean fan blades and housing, lube fan with machine oil on bearing underneath shaft-located sticker (I typically just tape or glue the sticker back on).
If the transformer is mounted on four corner bolts, tightening the mounting bolts can reduce hum. Likewise, tightening any bolts that hold the transformer plates together and reinforcing with varnish may reduce/eliminate hum.
Beyond that, tightening all mounting bolts and, sometimes, adding a mass deadening mat can work.
Good luck with a fix.
BTW, ascertain that it is indeed the converter and not a buzzing breaker. That can lead a guy off course.
