Sam_Spade
Dec 18, 2019Explorer
The problem is pretty simple; the solution might not be.
Your batteries are NOT connected to the converter.
OR....it might be more useful to state it the other way: Your converter output is not connected to the 12 V system in the RV, including the battery.
While a meter is an indispensable tool, physically tracing the output wires leaving the converter might be necessary here.
BUT....what exactly do you mean that the fuse "appeared good" ?
You have a meter, test it.
If it is good, you should see the converter output voltage on BOTH sides when the converter is running.
