time2roll
Dec 18, 2019Nomad
If the converter is producing 13.2+ volts and the battery is a bit lower.... you have an open circuit. Use that voltmeter and check voltage along the path to the battery. At some point you will drop from converter voltage to battery voltage. Need to repair, replace, adjust, clean, or tighten that point where the voltage changes.
