ticki2
Dec 18, 2019Explorer
It seems that you have the converter output going directly to the battery and the from the battery to the fuse block . When you disconnect the battery it in turn disconnects th converter from your 12v system . It should be converter to fuse block then fuse block to battery . That way you have power from either converts or battery . The converter you have will power 12v system with or without battery . A fuse can look good and still not be , try another fuse .
