ticki2
Dec 18, 2019Explorer
biggjb wrote:Could be off your picture but I am not seeing ground/white wire from converter connected to the ground lug on fuse panel , only battery ground .AnEv942 wrote:
The 'blue' wire mentioned was the lead from the old Mag. converter to the circuit board. The new P/D converter lead isnt blue, Mine was black, (current units may be red?). Would be outlined in instructions.
Assume you changed the board
Ya if no 12v when plugged in and battery off, something is disconnected.
Trying to see how you could have 12v to fuse panel yet not charge.
possibly battery lead connected to the converter terminal on board?
Your installation is very similar to mine. The lead wire on my board is black as well as you can see in my photo
and yes I did change the board. My only concern is the positive wire from the battery. I will have another look at it tomorrow.
