JRscooby
Jul 25, 2020Explorer II
valhalla360 wrote:JRscooby wrote:
One point the Lot of work for no money crowd seam to overlook; Depending on the owners wants/needs, the camper can be made pretty simple.
Example. Most RVs have carpet. I prefer a floor that can be cleaned with a broom, or at worse, a mop. Some places, like next to bed, a soft floor feels better. A rug, that I can take out and shake, or throw in washer works. And in small area, dirt/mud can be tracked next to bed. Move rug out of way until bed time.
Buy a cheap small trailer. Most come with vinyl flooring if not rip out the carpet and put it in and you have an easy to clean floor.
The carpet is just 1 example. I prefer to cook and do dishes outside. If I was converting a cargo trailer, I would mount sink and stove to back door, at a height to be comfortable to use while standing on level ground. If needed, could bend or sit to use inside.
My point is, DIY, you can make it as simple as you want, in both construction and use.
