eHoefler
Jul 28, 2013Explorer II
A new axle would be around $300 with electric brakes. A new Torsion axle with electric brakes is just under $500. Both rated at 3500 pounds and 6 hole wheels, 5 hole hubs are about the same price. If it is a spring suspension, most anyone can change it with common hand tools. Then all you need is the break away switch, wire it into the plug and a brake controller. Redneck Trailer supply has everything you would need.
44,068 PostsLatest Activity: Jun 21, 2026
