Francesca_Knowl
Jul 28, 2013Explorer
Brakes were offered as an option on lots of trailers back then, so chances are good there's a flange there. Also: If there's a flange, that MIGHT be a sign that the hub/drums already on the trailer will accept the addition of brakes. Many manufacturers used the same hub assembly whether the customer up-bought the brakes or not. Bad news is that after forty years the surfaces might not be good enough for the addition of the brakes.
But even if starting from scratch, I still think it's possible to do the job for a hundred dollars a wheel. My local autoparts store matches E-trailer's prices, and here are those for all parts to add 10" brakes to a light trailer:
Flange: less than ten dollars, but it must be welded on by someone that knows what they're doing. link.
Per other parts: A 10" brake assembly, and matching hub/drum total about $90.00.
44,068 PostsLatest Activity: Jun 21, 2026
