Loopy
Nov 01, 2008Explorer
MarionMedic wrote:
You can NOT use anything but the plastic/nylon "plugs" in my heater.
it doesn't use an ANODE ROD either.
I might re-do the setup at a later date.
I have the original plug I can use if it doesn't work.
I might get a braided nose this spring, but for now I'm trying this setup.
It's an "experiment" as are ALL mods that aren't "store bought".
Looks like the same water heater I have in my Jayco (Atwood 6 gallon DSI) in which I use a brass fitting to adapt to the braided stainless steel.
There's no reason you can't use brass in the threads on the water heater.
44,026 PostsLatest Activity: Mar 01, 2025
