TreeSeeker
Jun 07, 2011Explorer
I was thinking silver would be a good first coat. Silver tends to block all light and covers better than white. Most of the white paints I have used don't cover very well (slightly translucent). Use flat-black as a second coat, since it will reflect less light that does come through the louvers.
Or if you want it to look white from the outside, use white, then silver (for IR reflection) and then black. Flat black would reflect less light that is coming in through the louvers.
44,029 PostsLatest Activity: Jan 21, 2025
