boatwhyteh2o
Feb 18, 2012Explorer
I have often seen questions about what we are using to attach items to the thin walls of our trailers and RV's. I almost never use a screw unless it's going into solid wood. I use a variety of fasteners. I have used peel pop rivets, Tri-bulb pop rivets, plastic "Christmas tree" rivets and the center push plastic rivets. I have used the Christmas tree rivets to plug holes left for any number of reasons..my mistakes. This would be an example how I use the fasteners, my entry level TT has valences with fabric covered vertical sides. They are attached by little "L" brackets and tiny 1/4" screws to the vertical piece and the wall. If the valance is bumped the little screws come out stripped. So I attach the vertical to the "L" bracket with a peel rivet, and the "L" bracket to the wall with a removable plastic rivet. If I ever remove the verticle the hole will be plugged with a "Christmas tree" plastic rivet.
Sorry for my ramble, and I can't get pictures now or I would post them,
brooks
brooks
