gregrc75
Mar 28, 2012Explorer
wbrown62 wrote:Fisherguy wrote:
Looks like that key hanger is held on by velcro? That come as one pice or did you buy the pieces and make the board, that's a good idea.
The key board was purchased at Target. It is stuck on using the 3M Command strips (great stuff! We even have a few larger pictures hung up with the strips). I left a small bit sticking out in case I wanted to pull it off and move it. I don't like the white bit showing so I am going to trim it off next time out.
Thanks
I have a Bullet Premier and the wardrobes look the same. How did you add the shelf? I like that idea!
Nice discovery with the extra space next to the water heater. In my Bullet the extra space next to the water heater is open to store shoes when you take them on and off. You could open one of the sections and do the same if you wanted. Picture one of the sides with an opening or removed. You can see it in this picture, it is the base of the bench.
