wbrown62
Mar 28, 2012Explorer
gregrc75 wrote:
I have a Bullet Premier and the wardrobes look the same. How did you add the shelf? I like that idea!
Greg, I purchased a 4' x 12" pre-made shelf board at Lowes. It is pressboard with the laminated finish to look like real wood. I was too lazy to finish an actual piece of wood. LOL! I also purchased 2 pieces of 5/8" square dowels for shelf supports. I cut the dowels around 10" long, 2 for each wardrobe. I then used a framing square and drew a horizontal line on each side of the wardrobe at the same height. I stained the dowels and drilled 2 holes in each dowel. I attached the dowels, one to each side, with 2 screws and a little glue for good measure. I cut the shelf the correct length and just placed on top of the dowels. Because of the fit of the shelf, I had to have it in place and shoved up a little before screwing in the dowels. Once the dowels were in place, the shelf sat down perfectly on the square dowels. I added just a spot of glue at each bottom corner of each shelf just so they wouldn't bounce around. Actually they were kinda snug so probably wouldn't have anyway.
