welove2drive
May 19, 2012Explorer
PennyPA wrote:
Where did you put these expansion tanks? Looks like the pictured one is in the house as opposed to the basement next to the pump. And what did you tap into? I don't see how this would alleviate the pump noise though since the pump would have to go on as you use the water in this tank, wouldn't it?
I have a travel trailer so mine had to be in the house as you put it. Just so happens its in the same cab. as my pump. Came right off the pump to the tank and then on to the rest of the water system. As others have said I set the tank pressure at or just below kick on pressure for the pump. I can run a faucet at full for 30 sec. before the pump comes on.
