Bit_Bucket
May 20, 2012Explorer
Fisherguy wrote:
How much do you think all that weighs? Do you know how much it reduced your tongue wt by? Your genny a diesel?
With a full tank (6 gal) of gas, 70 lbs of steel, 113 lbs of genny, and the battery and plywood and other stuff, it weighs right at 285 lbs.
On the tongue of the trailer, there is (4) 6 volt batteries, and under the bed in the front of the trailer near the batteries is a 2800 watt inverter.
Using my Shurline tongue scale before and after, I measured my tongue weight as increasing about 50 lbs (but it is hard to really tell because I get about +- 30 lbs readings on the shurline, depending on whether I am lifting or lowering the jack).
I can load the trailer in ways that easily add or subtract about 150 lbs from the tongue weight, which tells you how much beer and other unnecesary *stuff* we carry with us. :B
