bigcitypopo
Jul 08, 2013Explorer II
campthewestcoast wrote:Mike Schriber wrote:
Okay, here's another one. Like everyone else, my water pump was really annoying. To quiet things down and improve the flow, I slightly relocated the pump and remounted it on a foam and plywood sandwich. This cuts down on transmitted noise. I also added a two gallon accumulator tank and flexible tubing which smoothes out the flow, reduces how often the pump runs and quiets the system
Mike
I mounted my expansion tank vertical so the water drains out of it when I drain my system during the winter.
yo mike, will that tank wear the check valve on the pump side,.. when you connect to city water the valve closes so you dont back fill your fresh tank and overfill the system. or do you leave the pump on all the time... just curious
