JordanH
Aug 29, 2013Explorer II
I havent done so, but here are a couple possible solutions i thought up. You could cut this wire pantry shelf to size and hang with some command small wire hooks, therefore it wouldn't be permanent and could be removed with ease.
Pantry Shelf: http://www.kent.ca/kbs/en/product.jspnavAction=jump&navId=2275&prdId=7467097&skuId=7467097&catalogId=2275
Command small wire hook: http://www.command.com/wps/portal/3M/en_US/NACommand/Command/Products/Catalog/~/Command-Small-Wire-Hooks?N=5924736+3294772789+3294857497&rt=rud
Or you could use a plated slotted angle bar and attach it with heavy duty double sided tape and cut a shelf to fit out of whatever you wanted.
Angle bar: http://www.kent.ca/kbs/en/product.jsp?prdId=5611044&skuId=5611044&catalogId=2409
