PennyPA
Jan 01, 2014Explorer
If you measure very carefully, he will be glad to make the spice rack slides for you. Or, if you want to come to Las Vegas and stay at the Hitchin' Post RV Park (reasonably close to his home), he'll make the pantry and/or basement slides for you, LOL.
He got the pantry and spice rack slides at: Rockler.
Wood from Home Depot.
Basement slide stuff from Amazon. The only thing he'd change on the basement slides would be to make sure he got "detachable" rails where you can detach the two inner sections from the main section in order to be able to use more of the screw holes into the wood.
He set the slides back from the front about an inch so he could drill holes into the upright 2 x 4 and we installed sliding barrel bolt locks on either side to keep the slide in place when we're driving down the road.
