Aluminum_Siding
Feb 08, 2014Explorer
balloonpilot wrote:
Travel Trailer Bunk Bed Rails.
I picked these up from a bunk bed store and cut em down. They already matched as far as the stain/color. The Ladders were purchased from the same store. I went through the plywood only on top and bottom of the bed with the brackets. Therefor I used boards on the bottom side to keep the bolts from pulling through. The brackets are from home depot and are 10 times stronger than they appear. I can stand on the bottom bunk pull hard and they hardly give at all.
cool mod!
My only concern would be someone getting scratched on the nut/end of bolt above the mattress.
I would suggest acorn nuts on the bolts for a smooth finish.
I concur. I ground the bolt flush with the end of nut then smoothed it with another polishing disc. You cant see it but bolt doesn't come past nut and it's flush and smooth. Good tip on the acorn nut. Never thought of that. Would have saved a bit of time. Good tip by the other poster too with the rubber caps.
