Heavy_Metal_Doc
Jul 15, 2014Explorer
gunner65 wrote:
Can you link to where you bought this box and if I could ask can you show how you mounted the box to the bumper?
Thanks It looks really nice.
I bought it from Amazon. Their information on the web is a little off, so I verified the size on Lund's site first.
http://www.amazon.com/gp/product/B007PY25DE/ref=oh_details_o01_s00_i00?ie=UTF8&psc=1
Lund/Tradesman 288271A
As for how I mounted it:
I just marked and drilled holes at each end to put the big u-bolts through which you can see in the pictures. I cut a piece of 1" steel angle (from Lowes) to fit inside the bottom corners at each end with the u-bolts through those also. Then I added a bolt through the box and angle at the outside overhanging corner to make the angle support the box and spread the load out to avoid tearing out the u-bolt holes.
Not sure I explain well in type, so here's a sketch.....I talk better with my hands!
