tenbear
Oct 15, 2014Explorer
tfolks206 wrote:
Thanks tenbear,
I should have said I dont want to add new outlets, just change one or two in the locations we charge our phones.
Are these correct?
Bulbs
The outlets you want to replace are probably the RV type and may not be in a box. The new outlets have the terminals exposed so you should put them in boxes just like household wiring.
The LEDs look the same as the cob style I used except these are white. I used warm white. The white may be blueish??? I assume you checked your lights to see what base is used.
I have found a big variation in sellers on eBay. Without having seen these lights I can't say that these are ones I would like. I always bought one or 2 to try before buying all I wanted. At the price, you wouldn't loose much if they were dimmer than expected or the color was too blue.
