T3rry1
Apr 01, 2015Explorer
Jdizzle wrote:
How did you connect the wires to the LED strip? In the middle? Did you solder them?
yes and yes, you can either cut the strip at one of the cut spots and solder them back together with the wires in between, or just cut out a chunk of the epoxy on it and solder to the contact points... you oay also be able to use a ("solderless") strip connector, but i have never used them
