RSD559
Jun 28, 2015Explorer
This was my project for Saturday. Got the box from Harbor Freight for Father's day. It's made for their little ute trailers, so modifications were needed. First, I needed new u-bolts. They were only 4" long. Tractor Supply has 2 x 5s. I also needed a new lock mechanism. The original is blocked by the propane tank. Got the hasp at a local hardware store, and the cool lock that doesn't bounce from Harbor Freight. And, I got some large self-tapping screws and fender washers. Drilled new holes for the u-bolts, and two large 5/8 holes for the battery wires. Yes, they have grommets in them. For good measure, I put the screws and washers to anchor the back of the box to the a-frame. I used some strap brackets, again from Tractor Supply, to hold the battery box in place. It locks up the battery, and has room for all of my set-up and emergency gear. Note: the two goopy screws are where the propane regulator was mounted. Haven't figured what to do with them yet.
